Reversing the path
Hi all,
I am using ‘Reverse elements’ from lens data to reverse my finite optical system in sequential mode
. what parameters should be constant during reversing optical system? I want to recheck that my system configuration has been correctly reversed or not. That’s why for recheck I want to know the parameters through which I can analyse that my work is correct or not.
If anyone has any suggestion or experienece, Please advice me .
Thanks in advance.
Best answer by designerguy13-photonics
sanjeev kumar.singh wrote:
Hi all,
Thanks in advance.
Hi @sanjeev kumar.singh ,
I look at using the reverse element option itself as a constraint method.
Now if it is about reversing a simple singlet plano-convex lens, you might want to keep the back focal length as a variable and others factor constant. because others parameter will be automatically reversed. But that also changes when you use some solver. Simply reversing though doesn’t seems to have that complications until you know why you are doing so.
Hi all,
Thanks in advance.
Thanks Anurag
