Relative illumination at a given Y depends on field type
  • Jan 15, 2025 3:26 PM UTC
  • 109 views
mocquin
For a given system, with field type defined as “Real Image height”, the relative illumination at say Y=2mm is say 0.95
For the same system, with field type defined as “Paraxial Image Height”, the relative illumination at still Y=2mm is now 0.92.
Since the Y coordinates of the relative illumination curve are given in mm in the image plane, I would expect the relative illumanition value at a given height is independant of the field type selected.
What am I missing ?
  • Jan 16, 2025 3:59 PM UTC
Hi Mocquin,
You are comparing RI at two different positions:
  • When using Real Image Height, you are looking exactly at 2mm.
  • When using Paraxial Image Height, you are looking at the RI at a point probably close to 2mm, but it could be 1.95mm or 2.1mm (or something else, this is just an example). “Paraxial” is an approximation.
