Rays passing above the first element
  • Aug 18, 2021 1:18 PM UTC
  • 96 views
Hello everyone,
In the picture above my question is;
Why are that portion of rays passing above the first lens? and how can I fix the rays
Thank you in advance,
Best regards
  • Aug 19, 2021 12:33 AM UTC
Hi Onder,
Assuming this is sequential mode, maybe the stop is in front of the lenses? And the semi-diameters fixed? OpticStudio fills the stop, but when rays miss a surface they are terminated. If that’s the case, you might want to choose another surface for the aperture stop.
If that’s not the case, is this sequential or non-sequential? What is the system aperture set to, and what surface is the stop?
  • Aug 19, 2021 6:06 AM UTC
Hi David,
Thank you for your response,
This is a sequential mode, my aperture set is defined as image space F/# and my stop is adjusted as a surface at the very back side which is not seen in the picture.
I draw a dummy surface at first to see the rays incoming, and when I take out this first dummy surface the weirdness clear out.
