Radiometric Analysis using Grating
  • August 19, 2023
  • 148 views
Hello All,
I am working on design consisting a grating. Analysis in  sequential mode shows all desire wavelength of -1st diffraction order is coming at the desire position of detector after diffraction form Grating.
But when I have converted this file to non-sequential mode for radiometric analysis, I found all the diffraction order (-2,-1,0,1, 2) is having same power. But in actual case, zero order should have maximum intensity compared to other diffraction order and intensity should gradually diminish as we move away from zeroth order in +ve and -ve direction.
How Zemax is calculating radiometric data for different diffraction order?
Sample file I have used for the analysis is attached here for your reference.
Thankyou.
Best answer by PhotonHerder
Zemax can’t calculate diffraction efficiency. To do that you need RCWA, FDTD, or other electromagnetic modeling code.  Lumerical, RSoft, VirtualLab, etc.
PhotonHerder
Yang.Yongtao
  • August 28, 2023
hi
I also tried to calculate the efficiency of gratings...
need to upgrade to a Zemax premium version
and get the data of gratings from the maker
for your reference(maybe you have already read this)
https://support.zemax.com/hc/en-us/articles/1500005578722-Simulating-diffraction-efficiency-of-surface-relief-grating-using-the-RCWA-method
