Question about accuracy of CENX/CENY
  • June 15, 2026
  • 203 views
Dear all,
In the manual, it is written : “Samp: The grid size. A value of 10 would yield a 10 x 10 grid of rays”.
I need to use CENX(Y) with the highest accuracy.
What is the maximum acceptable value of samp ?
Is there another way to increase the accuracy of CENX(Y) ?
Many thanks.
Thierry.
Best answer by Chris Normanshire
Hi Thierry,
The maximum sampling value for CENX(Y) is 100.
Kind regards,
Chris
Mike.Jones
  • June 15, 2026
This depends on how many waves of OPD are present at the FOV points.  If only a few waves, it's better for your extreme precision need to use the Huygens diffraction centroid.  CENX and CENY are geometric only and do not account for diffraction.  If the OPD is tens of waves then CENX and CENY are sufficient.  I start out with the default sampling values, note the centroid values, then increase the sampling until the centroid values differ only in the 4th or 5th decimal.
Hi Mike,
I’m working on the design of the future space telescope HWO, and especially the distortion over hundreds field points, for which the telescope is diffraction limited.
I know well CEHX(Y), but these operands are much too slow (even with my i9/20 cores) if you increase the accuracy (pupil and image samp).
This is why I prefer to use CENX(Y). So, is there a maximum value for the samp parameter ?
Thierry.
Chris Normanshire
Hi Thierry,
Kind regards,
Chris
Many thanks Chris.
Thierry.
