Problem while converting to Blackbox
  • October 11, 2024
  • 57 views
Mubeen Mahmood Puthiyangadi
Hi all,
I am encountering a problem while i convert design to black box. Design is with multi configuration. Is it possible to convert the design having multiconfiguration ino blackbox?
  • 1159 replies
  • October 11, 2024
@Mubeen Mahmood Puthiyangadi
I’m not sure, but it doesn’t sound like it should be supported. Why not have one black box per configuration?
Thanks for the reply. I am not aware of making black box per configuration. Do you have some inforation to share or any article on how to implement it.
Thanks
  • 1159 replies
  • October 11, 2024
What I mean is that for each configuration, you delete all the other configurations (so your file becomes single configuration) and you save a black box. Then, you will have as many black boxes as you had configurations and your user can setup a multi-configuration with the different black boxes.
