Problem in refractive index on non sequntial mode
  • Jan 9, 2024 12:29 PM UTC
  • 5 replies
  • 298 views
Hi all,
I have a problem in nsq simulation where the refractive index of one of the lenses is not working properly.
The problem is obejct 12 & 15 interface- they are from the same material but there is refraction on the interface.
Thanks in advance,
Nadav
@nadav.amitai,
Sorry if I wasn’t clear. The Object 1 is just a red herring. As I mentioned the problem is that the two surfaces are not touching each other (they are not within the Glue Distance). Currently Object 12 is at Y Position = 15.3, and Object 15 is at Y Position = 19.27, the distance between these two object vertices is 19.27 - 15.3 = 3.97. However, the Thickness of Object 12 is 3.96825673794112754, which means your two Compound Lenses are 0.00174326205887246 lens units away (which is greater than the default Glue Distance of 1E-6). You can solve it by adjusting the Y Position of Object 15. I’m showing an example with a Pick-up below:
Does that make snese?
 Hi @nadav.amitai,
If you zoom into your Layout, you can see that the two surfaces are not exactly in contact.
If you run a raytrace with a couple of rays and save the raydatabase, you can then examine a ray:
In blue you can see the segments of the ray that are relevant. At segment 17, the ray hits Object 12 while it was in Object 1. At segment 18, the ray hits the other end of Object 12 while it was still inside Object 12. Finally, at segment 19, the ray hits Object 15 but it was in Object 1 (N-Bk7) instead of 12, which is probably why you still have the refraction.
Am I making sense? Take care,
  • Jan 9, 2024 6:55 PM UTC
Hi David,
Thanks for the answer, but I do not understand how the ray can suddenly be inside object 1.
How I make this ray trace?
Nadav
  • Jan 10, 2024 7:19 AM UTC
Hi
I am adding the sequntial mode of the file. Maybe it will help to understand what I am trying to achieve.
Moreover, I add the nsq file again.
Nadav
  • Jan 10, 2024 12:09 PM UTC
@nadav.amitai,
  • Jan 10, 2024 5:26 PM UTC
Hi David,
It’s works now! Thanks for the detailed answer.
Nadav
