POP question: how to set up POP if waist X and Y are in different location as well as different size?
  • May 16, 2022 11:30 PM UTC
  • 177 views
Ying
I did laser beam measurement and knew waist X and waist Y, and their corresponding locations W.R.T laser port, just want to discuss with you what is the best way to set it up in POP.
what I did is to use Astigmatism Gaussian.
Since the 1st surface is x-waist, the waist position X is 0.
and waist position Y is 148 since Y waist is at 148 to the right of 1st surface - X waist.
Does this sound reasonable to you? I am a new user with POP, any suggestions and advice are appreciated!
Thanks!
Ying
