Optimizing a real lens focal length for a system
  • Oct 11, 2020 3:49 AM UTC
  • 1136 views
Hi fellows,
When I insert a real lens to focus a light in a system, Is it a good practice to set its focal length to a variable for optimization purposes?
In this image below, surface 2 contains the focal length of the lens in the 'thickness' which is the space to the detector where light is focused. If I optimize this variable and get a nice result, how do I approach this real lens in the market if I am looking for off-the-shelf lenses? Or should I request the manufacturer to make it for me to suit my design?
Thank you very much.
Naif
Best answer by David
Hi Naif,
The thickness of surface 2 is not the focal length of the lens. It is the back focal length, which is the distance from the vertex of the last exit surface of the lens to the image plane. This is close to -- but not equal to -- the focal length because for a thick lens the focal length must be measured from a theoretical surface called the principal plane. (I suggest you Google that.)
The real lens you have inserted is in fact a real lens offered by a vendor. In this case, it is P/N 47-182 from Edmund Optics. It has a focal length of 254 mm at a wavelength of 10.6 um. This is a lens for IR applications. That is the usefuness of the lens catalog -- you can actually buy the lens. (One-off custom lenses are VERY expensive.)
See https://www.edmundoptics.com/p/254mm-dia-x-2540mm-fl-uncoated-znse-plano-convex-lens/7209/
Kind regards,
  • Oct 12, 2020 7:28 PM UTC
Hi Naif,
Kind regards,
  • Oct 14, 2020 12:45 AM UTC
Hi David,
Thank you very much for this crystal clear explanation.
I appreciate your amazing contribution to this massive platform.
Best Wishes
Naif
