Optimization of optical system - Diverging output wavefront
  • September 7, 2026
  • 66 views
CJ27
Hello again friends from the Zemax community,
I’m trying to optimize an optical system in where I have an input spherical wavefront (a single point) and the output is another spherical wavefront with a changed radius of curvature.
Since my image is not real at the target output plane, how could I use zemax merit function definitions to optimize such a system?
Would optimizing for the spot size/wavefront error at the “virtual” image point in image space be a suitable solution here? Or is there any other approach that I could follow?
Thanks a lot for your feedback and comments
Mike.Jones
  • September 7, 2026
Yes, locate the virtual image point (plane?) where you want it, and optimize the WFE there.
Just a tip from an old battle-scarred-but-good-memory lens designer: NEVER optimize with only a zero FOV.  Give this some FOV, even if small, just anything to generate off-axis merit function operands to minimize.  This makes your system much less tilt-sensitive, at least over the FOV.  This also gives tolerancing something to work with as well.
CJ27
  • September 8, 2026
Great,
Thanks for the feedback and help!
