Openning zmx creates lots od firectories
  • June 23, 2025
  • 9 replies
  • 127 views
mocquin
I have several zmx files in a folder, but only one of them creates lots of fempty olders when I open it while all others don’t. What is it that determines the behavior of a zmx file regarding folders like Apertures, CAD Files, etc
I tried turning off projectdirectory with the API but still the folders are created.
  • June 23, 2025
Hi Mocquin,
This is determined by the “Project Directory” options, in the “File“ menu bar and in the System Explorer
You can also access the opiotn in the zmx file, close to the top, with the line:
IWDP 1
1 means activated, 0 means deactivated.
mocquin
  • June 23, 2025
Yes I know, so I deactivated the “project directory” option, but it still creates new empty folders when I open the zmx file
Sean Turner
  • June 23, 2025
The ZMX file creating extra directories was saved as a lens project. The others were not. You can open it and convert back to a lens file from a lens project and it will not create the extra directories in the future.
mocquin
  • June 24, 2025
Thanks ​@Sean Turner but I’m not sure what you mean by “convert back to a lens file” ?
As of now, when I open the zmx file, it creates said folders, and the toolbar looks like this :
and the file is not a “project directory” :
  • June 24, 2025
Hi Mocquin,
If you open the file in a text editor, does it say
IWDP 1
or
IWDP 0
at the top ?
If 1, set it to 0 or remove the line (use a copy of the file if you want to be safe)
mocquin
  • June 24, 2025
Line 5 in the file is :
IWDP 0
mocquin
  • June 24, 2025
Is it possible this comes from the fact that the file contains a blackbox row ?
@mocquin
I don’t know if it will help but you can also try what ​@Sandrine Auriol suggested here:
That is, with the ZOS-API:
TheSystem=TheApplication.PrimarySystem
TheSystem.TurnOffProjectDirectory()
I’m not sure if it does anything different than switching to IWDP 0.
mocquin
  • June 24, 2025
@David.Nguyen  Yes I already tried that as well, with no effect...
