Object Space NA
  • Sep 12, 2023 11:44 PM UTC
  • 656 views
anis2073
I am trying to see the effect of NA on my system, and was wondering if there is a way to change the NA in ZPL.
Best answer by Christian Zimmermann
Hello anis,
I would suggest to use Zemax help for further information on ZPL aperture settings.
» ZPL set aperture
SETSYSTEMPROPERTY, SYSP
Sets properties of the system, such as system aperture, field, wavelength, and other data.
Syntax:
SETSYSTEMPROPERTY code, value1, value2SYSP code, value1, value2
Also compare attached code table below to set aperture type to OSNA ( object space NA ).
Kind regards,
Christian
Code Property
4
Adjust Index Data To Environment. Use 0 for off, 1 for on. See “Adjust Index Data To Environment”.
10
Aperture Type code. See “Aperture Type” for code values and discussion.
11
Aperture Value. See “Aperture Value”.
Hello anis,
» ZPL set aperture
Syntax:
Kind regards,
Christian
Code Property
4
10
11
anis2073
  • Sep 29, 2023 12:38 AM UTC
Thank you very much I will try this.
