NSC: Two diffraction questions.
  • Aug 16, 2024 12:21 PM UTC
  • 202 views
dkominsky
I’ve got two questions about using diffractive elements in NSC.
  1. Is there a simple way to pick up diffraction direction so I can put the next element in the correct location?  The only way I’ve found is to use a ZPL solve which has to be unique to the specific object in order to pull out all the information about the lines/um, orientation, etc.  I could even do it in multiple steps with pickups, but none of the math functions are available in the in editor pickup options.  Alternatively, is there a way to make Zemax trace one ray and use that as the direction to the next object?
  2. Modeling a rectangular diffraction grating. I’ve tried two approaches:
    1. One is creating a boolean of a native diffraction grating and rectangular volume, but that seems to give different diffraction differently than it does if I just use the native grating
    2. I know that there is the UDO/DLL, which has tons of different grating types in it, but I am running into two problems with doing that.  First I can’t find a sufficient explanation of the various parameters to know how to set it up.  Second, I don’t see any way to optimize any of those parameters, since they are not available in the LDE
Any pointers would be greatly appreciated.
Thanks!
Best answer by Jeff.Wilde
@dkominsky:
  1. Regarding use of a “probe ray” for locating objects in NSC mode, this previous post may be of some help :
  2. For a rectangular grating, the help documentation points you to a simple solution:
Here is a simple example:
  • Aug 17, 2024 5:25 PM UTC
@dkominsky:
