NSC modelling deformed mirror
Hi there,
I am thinking of modeling a specific deformation on a mirror in my set up to help develope a pass/fail criteria. I have an interferogram (Zygo image) but I cannot make it into a Zernike model (it is rectangular), I will have to estimate and approximate the shape of the mirror by the data given. Attached an example.
I can convert the profile cross-section (marked with red arrow) from fringes to microns, that should not be a problem.
My question is: what non sequential object would you recommend that I’ll use for the mirror?
Thanks!
Kevin Scales
Hi Ornit,
The attached files are not that easy for me to read or understand. But if I were to take a stab at answering this, I think my best best would be to go ahead and use your sag data to create a Grid Sag Lens. They can be rectangular and can take an arbitrary shape on the back surface. A Grid Sag Lens 2 will also work, though it supports front and back surface effects, which is more than you need here.
Kevin
Thank you Kevin!
I will try Grid Sag Lens.
Thanks
Ornit
