NSC editor not showing cells
  • September 28, 2023
  • 5 replies
  • 110 views
Hi together,
With the last Zemax Version (ANSYS R2.01) I have such funny behavior of the NSC editor. Sometime (e.g. add ne object) the cell number and the whole row is not shown.
Has somebody seen that?
  • October 4, 2023
In addition I see sometime wrong index numbers for the rows which is a nightmare when working with the Merit Function.
  • October 4, 2023
Hi @Photoniker,
I haven’t experienced this issue yet. Do you have a way of reproducing the problem or is that random? It seems like you have quite a few lines in your NSCE. Is that also happening with fewer lines?
  • October 4, 2023
I haven’t experienced this issue with fewer lines. Indeed there are hundreds of lines. Unfortunatly we have to work with such big model to have the whole optical system. So far, I have seen this issue randomly without reproducing it. Maybe it is related to some hidden lines?!
  • October 4, 2023
Hard to say, anything you can tell that helps reproducing the issue might help. Does it happen always between the same objects?
  • October 4, 2023
I happen when I add a new line as shown in the screenshot at position 236.
Funny observation: If you change into the express view, it looks right. Changing back looks wrong again.
