Multiple pinholes
  • July 28, 2025
  • 150 views
Hi members,
I’m trying to create a system that the first surface has multiple pinholes, similar to this glasses:
is there any way to create this without using CAD files?
I thought of using multiple fields from different locations but I can’t remember how (and if) i (can) control the beam size.
Yang.Yongtao
  • July 30, 2025
hi Nim
  I am not sure the first surface you mentioned is the OBJ or field
for field  maybe this helps, but needs a distribution combination
for obj, how about using a slide surface?
Yang
  • August 3, 2025
Thank you yang,
The slide surface can defiantly help 👍
