modelling surrace irregularity on Biconic surface
hello,
I have a biconic surface I would like to perform an irregularity tolerance analysis on.  I read about using TEZI.  How can I use this for a biconic surface?
John
Best answer by Jeff.Wilde
You could try using the composite surface capability: Introduction to Composite Surface
  • 491 replies
  • July 17, 2023
  • 5 replies
  • July 19, 2023
Thanks Jeff!  I will look into this.  Hope you are doing well!
John
  • 491 replies
  • July 22, 2023
Hi John.  Yes, all is well; good to see you on the forum.
The relatively new composite surface looks interesting, especially for tolerancing.  However, there is a note in the help documentation that indicates it doesn’t work for off-axis apertures, so it has some limitation.
An approach to tolerance off-axis surfaces is described here:
Tolerancing surface irregularity using a phase surface
