Modeling Laser Source
  • October 9, 2023
  • 356 views
Unsig
I need to model laser source in beam propagation with following constraints.
beam size: 5 mm
divergence angle: 400 urad
M2 = 1.5
wavelength: 1064 nm
I appreciate in advance.
Unsig
Best answer by Mark.Nicholson
Hey Unsig,
This is using POP? Just use Gaussian Size and Angle as the beam definition:
M^2 can’t be entered separately, but the beam size and angle should resolve down to the stated M^2. That’s the point of the Beam Size and Angle definition.
  • Mark
Unsig
  • October 9, 2023
  • 911 replies
  • October 9, 2023
Hey Unsig,
  • Mark
Unsig
  • October 9, 2023
Hi Mark,
Thank you for prompt advice.
Unsig
