Missed Surface Error Message - Possible Solution Proposed
  • August 19, 2021
  • 2188 views
Hello Everyone,
On some occasions this error message might come across during my sequential studies. I recently figured out that while I get this error message (the aperture, in this case F/#) I can fix this error by increasing the  F/#. By changing the aperture to some certain limit of light fully accepted I jump into a result that this error messsage can be overcome by this manner.
Having comments on this thread is welcomed.
Thanks for your post here on the Community forums!
The error you are getting is telling you that critical rays are missing a surface. This means that the real raytrace is unable to be performed and your merit function cannot calculate correctly. You can see more specifically which rays are missing and giving you the errors in the System Check tool under the Setup tab. An error in the raytrace means the system is not “stable” and therefore invalid until those errors are resolved.
A possible way to fix this would be to set the vignetting factors in the Field Data Editor (FDE) by clicking the Set All Vignetting button in the FDE toolbar. This will set compression factors to the ray bundle tracing through your system such that the marginal rays are no longer clipped by any surface apertures and the merit function can calculate again. Looking at the System Check tool again, there should no longer be errors in the system. More information about using vignetting factors can be found here:
How to use vignetting factors – Knowledgebase (zemax.com)
I hope this helps, but if you have any further questions, please let us know and we will be happy to help!
Csilla
Csilla Timar-Fulep
Csilla
TLDR for How to use vignetting factors – Knowledgebase (zemax.com) :
System Explorer > Fields > Settings > Set Vignetting
Should eliminate the error.
  • 50 replies
  • February 25, 2022
Thank you for your help Barton.Plimmer,
Would there be some trade-offs while setting vignetting?
