Merit function, secondary focal point optimization
  • Sep 2, 2021 1:17 PM UTC
  • 496 views
I have a system which I would like to optimize with low rms spot size. However I would like to keep the beam collimated where the arrows are pointed. I am not sure how to setup the boundary conditions in merit function.
Thank you in advance.
Fatemeh
Best answer by Mark.Nicholson
Hi again Fatimeh,
The IMSF operand is your friend. Check the docs, IMSF lets you define the image surface on the fly inside the merit function. So you can
IMSF {intermediate focus surface)
Default RMS Spot Size MF
IMSF {internal collimated space}
Default angular radius MF
IMSF {Final Surface}
Whatever your final Image Quality MF is.
It’s cool and exactly what you need for this kind of problem. When using the Optimization Wizard, use the ‘Start at’ control to make it write the intermediate merit functions without overwriting each other. I think there’s a KB article on intermediate surface optimization.
  • Mark
Hi again Fatimeh,
  • Mark
Another way is to create a multiconfiguration system and turn off several surface in one configuration.
I can see that IMSF is a very useful function.
Thank you Mark.
