Merit Function Listing: how are the constraints and sequential component combined to yield the Merit Function Value?
  • August 21, 2026
  • 98 views
In the Merit Function Editor there is the option to generate a Merit Function Listing. At the top of the Merit Function Listing three summarizing lines are listed: “Merit Function Value”, “Constraints Merit Function”, and “Sequential Merit Function”. The “Sequential Merit Function” value results from the used “Default Merit Function” and the “Contraints Merit Function” value from all the operands added to the Merit Function (e.g. contraints controlling geometry, MTF, distortion...).
My question: How do the two component values combine to yield the “Merit Function Value”?
Best answer by Jeff.Wilde
  • August 27, 2026
  • August 27, 2026
Thanks a lot, Jeff!
I should have been thinking about the maths before raising the question. The merit function components cannot be used to calculate the total merit function value. All individual deviations and their weights have to be used instead.
