MCE script operand via ZOS-API
  • June 21, 2023
  • 124 views
gneplyakh
Dear Zemax Community,
I have a question and would be very thankful for an answer.
Is it possible to have a ZOS-API script be run whenever an MCE-operand is called? This way I could have configurations  with for example different beam waist sizes for POP or Paraxial Gaussian Beam Analysis. Something that is not possible in native Zemax yet (as far as I know).
It would be a very useful and versatile functionality if it is not implemented yet.
With kind regards,
gneplyakh
Hi Gneplyakh,
I don’t think you can have user-defined Multi-Configuration operands. However, it is possible to change configurations from within the ZOS-API. Can you clarify what you want to achieve, I think it should be possible with the ZOS-API.
