lens type setting operand in configuration
  • May 24, 2021 11:36 PM UTC
  • 289 views
I would like to change lens type in multi configuration.
In specific surface, it may be sphere or toroidal. I will set a two multi configurations. One is sphere lens and the other is toroidal surface in SQ mode.
I check multi configuration operand in manual and can't find an operand that can handle this operation.
Kevin
  • May 25, 2021 9:55 PM UTC
Hi Kevin,
The way to do that is to include both lens choices in the LDE, and then use ignore operands in the multiconfiguration editor to ignore in each configuration the lens that should not be there. I attach a ZAR file with an example of both a best form and biconvex lens, each active in only one configuration.
Kind regards,
  • May 25, 2021 10:20 PM UTC
Hi David,
thanks
Kevin
