Lens system import into non-sequential mode
  • March 9, 2021
  • 1568 views
Nick Klaus.Metzger
Hello Zemax community,
I built a anlysis setup in non-sequential mode and designed a lens sytsem in sequential mode.
Is there a method to import this lens system into my non-sequential setup for anlysis?
Other than inputting every surface manually.
Export and the re-import as a CAD file?
Thank you for your help,
Nick
Best answer by David
Hi Nick,
Yes, there is a good method for this. Your sequential design can be converted to a non-sequential design using the 'Convert to NSC Group' button in the top menu strip. Then you can open the analysis setup design as a seperate OpticStudio instance and copy paste the objects into your non-sequential analysis setup, or you can paste your analysis setup into the newly created non-sequential file.
When the surfaces in the sequential file are converted to non-sequential, the surface defined as the 'Global Coordinate Reference Surface' in the Aperture tab is located at Z=0 in the new non-sequential file, so it makes sense to choose the global reference in the sequential file for convenience in the non-sequential. Once in the non-sequential you can alway change the reference object for the newly created ojects to make them dependent on a reference object so they can be moved as a group if needed.
This is much better than importing as a CAD file because you get the objects in as native objects.
Kind regards,
  • March 11, 2021
Hi Nick,
Kind regards,
Nick Klaus.Metzger
Dear David,
thank you for your help - it worked really well!
Very best wishes, Nick
