Lens cannot be traced, tolerances may be too loose vs mtf
  • Mar 21, 2023 8:45 AM UTC
  • 185 views
Hi all,
During tolerancing of some lenses (using the mtf as criteria) I get the “Lens cannot be traced, tolerances may be too loose!”
However, opening one of this the monte carlo files it seems like the mtf is bad but larger than zero.
What can be the reason for this?
Nadav
  • Mar 21, 2023 11:54 AM UTC
Edit:
geom mtf makes problem while diff mtf doesn’t.
