Layout zoom gets stuck
  • September 12, 2023
  • 8 replies
  • 384 views
Alberto.Donazzan
It randomly happens that zooming by scrolling gets stuck and does not work any more. It usually happens when coming back to the layout window from another window (being it an editor or an analysis tool). It never happens while working on the layout window itself.
“Reset zoom” does what it is supposed to do, but still zooming by scrolling is disabled.
A solution I found is to temporarily switch to Classic view and then switch back to Graph view.
Is anyone facing my same problem?
Best answer by Kevin Scales
Thanks to everyone who mentioned this. We do have bug reports on issues like these (freezing, strange graphics) so this is a known phenomenon. As with all bug reports, there’s just no way to know how long a fix may take, particularly when the problem is hard to reproduce and when workarounds exist, like opening a new window, toggling views, etc. I haven’t heard about cloning as a solution, but I’ll give it a try next time my own graphic window goes a little bonkers.
Sean Turner
I have also encountered this.
Sean Turner
  • September 13, 2023
Then there is the occasional bug where suddenly 3D layout looks like I just turned on the hyperdrive.
  • September 29, 2023
I’m also finding the 3D layout freezes, most often when I’m updating a parameter in another window, haven’t yet noted exactly what does it most regularly. It started in my last update of Zemax OpticStudio and is still in the newest Ansys R2 I’ve just switched to.
My best workaround is to clone the window. This keeps my settings and gives me back the working 3D layout.
It has definitely happened to me a couple of times since I updated to R2.00. Everytime I ended up cloning the window as @James.Parker is saying. I couldn’t identify a pattern that was causing the issue though.
Kevin Scales
  • October 13, 2023
Ray Jones
  • September 13, 2024
Still happens to me, 2024 R2.01.  It would be nice if this could get fixed soon...
  • September 14, 2024
@Ray Jones
I understand the frustration. If you want to help get the bug fixed, I suggest you describe how it happened to you. Also are you able to reproduce it systematically? What were you doing right bedore it happened? As
@Kevin Scales is saying, if the developers can't easily reproduce the bug it's extremely difficult to find the root cause.
Michael.Young
@Sean Turner, Have you considered selling your art? 🙃
