Launch rays (from an input fiber) at an angle
  • Aug 13, 2020 11:52 AM UTC
  • 748 views
I am making a model for a system that takes an optical fiber as an input. I have now done that by specifying the semi-diameter of the OBJECT surface 0 to represent the fiber core size, setting the system Aperture Type to 'Object Space NA' and specifying the known NA, and selecting the 'Telecentric Object Space'. I hope that's the best way to do that. If not, please let me know.
My question is about how to have this fiber come in and launch its rays into the system at an angle. It is an asymmetric system that will have multiple non-sequential groups in it, which will be much simpler to define if the initial chief ray already has the system's primary angle. I can not tilt the OBJECT surface with the Tilt/Decenter tool. I've tried rotating the whole system, but that seems to still launch the rays horizontally. Inserting a dummy surface with a coordinate break also does not appear to work. Any help would be appreciated.
Best answer by Berta.Bernad
Hi Wouter,
You can tilt the object plane using the 'Tilted' surface, so you can directly uses its parameters to define the tangents of the X and Y angles:
The Setup Tab > Editors Group (Setup Tab) > Lens Data Editor > Sequential Surfaces (lens data editor) > Tilted
I hope it helps,
Berta
Berta.Bernad
  • Aug 13, 2020 12:10 PM UTC
Hi Wouter,
I hope it helps,
Berta
