Laser gain medium and cavity dynamics
islandoptics
Monochrome
Can Zemax POP model laser cavity dynamics such as when a steady state convergence is achieved? Can POP using DLL, or ZPL model laser gain material and impacts onto propagated beam?
Any insight is appreciated.
Best answer by Mark.Nicholson
You can certainly model gain. Create a new material in the Materials Catalog:
and set its transmission >1 as a function of wavelength.
POP works in sequential mode, so you’ll need to define a series of surfaces for each pass. Pickups and copy/paste are your friends!
  • Mark
  • Mark
islandoptics
Monochrome
Thanks Mark.Nicholson! I had no idea you could set transmission greater than 1 in Zemax. That sounds like a perfect solution.
 - islandoptics
