Is the MFE related to the initial state after the parameter values in the lens data change?
  • Jun 19, 2025 3:02 AM UTC
  • 60 views
Dear community,
I’ve got the problem of lens data editor that  the MFE related to the initial state after the parameter values in the lens data editor changed.
I have the values of the specified parameters in three sets (A, B, C) of lens data editor, including thickness, radius of curvature, and eccentricity and tilt of coordinate discontinuations, etc..
I find that the coupling efficiency of B in MFE obtained from A-->B is different from that obtained from A-->C-->B. (After setting the parameters each time, I only performed the operation of refreshing the MFE and did not make any optimization.)
Why do the MFE results corresponding to the change of parameter group B from A and from C be different?
Looking forward to your answer. I really appreciate it!!
​@Haining.Yang
Any chance you could share a file that demonstrates the issue with us? Otherwise, its difficult to say.
What are the two MF values?
You mention coupling efficiency, are you using FICL?
Do you have aspheric/freeform surfaces? In complex surfaces, OS uses an iterative algorithm to find the ray intercept with the surface, therefore it can slightly vary depending on the starting point. I don’t think it’ll cause a major change in the MF value though.
