Importing freeform surface via grid sag - Data changing
  • Jan 25, 2024 9:30 PM UTC
  • 210 views
CJ27
Hello there friends from the Zemax community,
I have a freeform surface which was obtained via an external numerical routine.
My numerical routine provides me with the surface sag information (x and y coordinates and the associated surface height).
I have tried importing this surface into a sequential mode system via a grid sag object.
However, I can observe that the surface profile changes depending on the distance set between my previous surface and the imported freeform surface.
I would expect the surface to have the same extension always, isnt it?
Any comment or feedback will be highly appreciated!
Please post a file that demonstrates this.
CJ27
  • Jan 29, 2024 7:43 AM UTC
Hi Mark,
I think I have solved my issue. I just need to set the semi diameter to fixed instead of automatic and the surface extension remains the same no matter the distance to the previous surface.
Thanks.
