Image Simulation: “Oversampling”, “Pupil/Image Sampling, and “PSF-X/Y Points.
  • February 10, 2021
  • 319 views
I have use Image simulation tool to evaluate the image quality of my setup. There are different parameters in its setting, and I wonder what the realistic values of this parameter are. In attachment I specified some of these parameters affecting the simulation results, such as “Oversampling”, “Pupil/Image Sampling, and “PSF-X/Y Points.
I really appreciate in advanced if someone can assist me regarding the correct values of aforementioned parameters.
Hi Pooria
Have a look at that article: https://support.zemax.com/hc/en-us/articles/1500005486701-How-to-simulate-high-resolution-images. It is a good starting point as it explains how to set up image simulations.
  • Oversampling: is a setting to increase the number of pixels of the input image
  • Pupil/Image Sampling: these are linked to the Huygens PSF.
  • PSF-X/Y Points: these are the number of PSF we are going to calculate across the field of view. Then the software will make some interpolation.
