In the image simulation analysis what is happening when I’m using a wrong ‘field height’?
What Zemax do when I’m using a larger field height and smaller field height?
Where can I read about the image simulation engine and how to adjust each field type for the image simulation.
When to define the pixel size?
Last question, lets say I have a lens designed for object height of 10x10.
In the Field Data Editor I set the object height to 5X7. What  field height should I use in the image simulation?
Thanks in advance.
Eyal
Hello Eyal,
Here are a few references to understand how Image Simulation works and how to set up this analysis tool:
Regarding your specific question:
The Image Simulation tool runs its own calculations, independently of what you set in the Field Data Editor. Therefore you can actually use any field height in the image simulation. Of course, vignetting and image cut-out will happen if you choose a field height larger than the field your lens was designed for in the first place.
