If I want to iterate through different zbf files as input for POP, could this be done in zpl?
  • Dec 19, 2023 12:08 AM UTC
  • 172 views
icybird
Is there a way to iterate through a list of zbf as input for POP? Could this be done in Macro? Any examples to refer to?
Thanks very much.
Hi @icybird,
Strictly speaking, there is the MODIFYSETTINGS keyword that can be used with:
POP_SOURCEFILE: The file name if the starting beam is defined by a ZBF file, DLL, or multimode file.
Note that:
The settings file must be manually created prior to using MODIFYSETTING
In my tests, there’s something odd with the case though. If you don’t write the file name with the right case-sensitivity, the script doesn’t complain but the File setting is empty. Not sure why this is happening, but better make sure you type case sensitive file names.
Here’s an example of how to use the ZPL keyword:
FORMAT 2.0
FOR ii, 32, 64, 32
# ZBF file name
file_name$ = "test_one_" + $STR(ii) + ".zbf"
# Change the ZBF file name
MODIFYSETTINGS "<path_to_cfg_file>", POP_SOURCEFILE, file_name$
# Create a new analysis
OPENANALYSISWINDOW "pop"
NEXT
In my example, I’m using two ZBF files that I already had that were named “test_one_32.zbf” and “test_one_64.zbf”.
Depending on what you want to do with the POP results though, it might be better suited to use the ZOS-API.
Let me know if that helps and take care,
icybird
  • Dec 22, 2023 4:18 AM UTC
Hi David,
Thank you very much for the hint!
