i9 13980 vs ryzen 7945hx
  • Jan 28, 2024 9:51 AM UTC
  • 6 replies
  • 439 views
Hi all,
I am thinking of upgrading my laptop in the future, and I wonder if zemax did some benchmark test between Intel core i9-13980HX and AMD Ryzen 7945HX?
https://ark.intel.com/content/www/us/en/ark/products/232138/intel-core-i9-13980hx-processor-36m-cache-up-to-5-60-ghz.html
https://www.amd.com/en/products/apu/amd-ryzen-9-7945hx
Furthemore, does 32GB ram is enough for both of these CPU?
Nadav
Best answer by Ty Adair
Hi Nadav,
I don’t believe any benchmark tests have been conducted in-house. For a general comparison between the two processors, there are a number of benchmark websites, such as “userbenchmark.com”.
Regarding RAM utilization: 32Gb should be enough for most types of simulations. RAM usage typically ramps up when the system is optimizing a very large number of non-sequential rays through a complex system and/or has imported CAD components. For these cases, 32GB should be OK, but maximizing memory on the machine would be recommended.
Here is a community post, where the user ran into insufficient memory for reference:
Ty Adair
  • Feb 1, 2024 6:54 PM UTC
Hi Nadav,
PhotonHerder
Post this to the Reddit optics group.  There’s someone there who will be able to answer this.
PhotonHerder
To the Zemax team: It would be great to get some detailed information on this.  The Intel CPU mentioned above has 8 “performance” cores an 16 “efficient”.  The AMD just says 16 cores.
Which one is faster?  Also, does the answer depend on sequential vs non sequential?
I don’t know about Intel’s marketing these days, but I distinguish between ‘real’ cores, which are actually part of the silicon, and hyperthreaded cores, which use a scavenging approach to make unused CPU cycles appear as a separate core. They’re software cores, rather than real. Real is best.
PhotonHerder
Hi Mark,
Yes but I’m referring to different types of physical cores.
https://www.intel.com/content/www/us/en/gaming/resources/how-hybrid-design-works.html
Based on that page, my guess is that Performance Cores are what a big number-cruncher like OS would use, while the Efficiency Cores would run smaller tasks like system-level processes. But it would be fun to play with one of these big boys!
