I let rays from a point source pass through a cylinder volume, 3mm long, 0.4 mm diameter, the rays exit from the cylinder volume has a multi ring structure. Why?
  • Oct 20, 2024 12:00 AM UTC
  • 155 views
Leon
Leon
  • Oct 20, 2024 12:03 AM UTC
The layout is here
  • Oct 20, 2024 9:10 PM UTC
Hi Leon,
It appears to be associated with the number of bounces rays make in the pipe. It’s always an integer number. In the attached file I used a Cylinder Pipe and a Source point. I show a detector with the rings you noticed. I also saved two ray files, one with rays which made two bounces, and one with rays which made 6 bounces. The ray files were saved using filter string X_HIT(2,n) where n in the number of bounces. I did not include the ray files in the ZAR because they are huge.
Leon
  • Oct 21, 2024 12:32 AM UTC
David:
Thank you for the reply.
