Hybrid Mode with multiple exit ports for a single NSC Group?
I have a NSC design of a dual Prism beam spitter with a dichroic coating on the splitting face. This dual prism set up creates sets of rays depending on the wavelength. I need to use this NSC Group as one element in an Image Simulation for a Lens, where the output from the lens passes into the entry port of the NSC group, but there will need to be two exit ports since the prism setup creates two sets of rays for two separate sensors that will need to capture different wavelengths.
How can I do this?
I figured one way would to use different configurations in Sequential mode where the exit port changes in the two configs, is that the only way or is there an easier alternative?
Thanks in advance from a beginner!!
