How to vary diffraction efficiency with incident angle for a grating object?"
  • January 27, 2026
  • 127 views
ztystar
Hi all,
Regarding the built-in grating object in sequential/non-sequential mode (especially in non-sequential mode): I know we can assign different diffraction efficiency (DE) values for different diffraction orders, but this DE is typically constant across all incident angles.
Is there a standard way to assign an efficiency profile that varies with incident angle without fully modeling the real grating structure (like with RCWA)?
For example, for the 1st diffraction order:
-10 deg incidence -> DE = 0.3
0 deg incidence -> DE = 0.1
+10 deg incidence -> DE = 0.2
I am looking for a behavioral model rather than a physical one to save simulation time. Would the best approach be writing a User Defined DLL, or is there a way to utilize a Table Coating to modulate the efficiency, or even other potential methods?
Thanks for any insights!
Kaden
Mike.Jones
  • January 28, 2026
You could also vary the source power with grating incidence angle according to RCWA predictions.
ztystar
  • January 28, 2026
Hi Mike,
Thank you! That is a clever workaround.
However, in my simulation, the light interacts with the grating multiple times (like in a waveguide). Since source apodization only controls the initial launch power, I assume it wouldn't account for the angle-dependent efficiency on the 2nd or 3rd bounce, correct?
Do you think using a Table Coating to modulate the efficiency vs. angle would be a more robust method for these multiple interactions?
Kaden
