How to turn off / modify Language Localization Support - comma to period
  • Mar 31, 2020 10:37 AM UTC
  • 672 views
OpticStudio seems to adjust the decimal separator according to the local language settings, in my case that means a comma instead of a period as separator. I'd like to change this setting back from commas to periods as separators but couldn't find a way to change it. How would I do that? Thanks for your help!
Best Regards
Hi!
OpticStudio is using Windows regional settings.
In Windows, you can change that setting under Control Panel...Region...Additional Settings:
I hope it helps.
Sandrine
Hi!
I hope it helps.
Sandrine
