How to target the EFFL in Non Sequential Mode
  • Aug 11, 2025 2:11 PM UTC
  • 232 views
mlisowski
Zemax in Non-Sequential:  I have a system with a grid of emitters, see below, and a detectors (polar and rectangular) about 1000mm away. I started by collimating the light which worked to get nice disscrete point; however, the magnification is not correct. I could change my target angle but this seems like it will just fuzz out the image.  I’d like to set the EFFL of the lens so that with the object to lens I get the correct magnification. What is the best way to do this?
​@mlisowski
You could calculate the EFFL in the Merit Function Editor (and Target it to a specific value).
The case of a plano-convex lens is relatively simple. You can also find the general calculations there (I am not affiliated with Edmund Optics).
Getting the refractive index in Non-Sequential is somewhat more difficult than Sequential, and its something we’ve discussed here:
The bottom line is that you should use a ZPLM operand with the Numeric Function NPRO (code 200 for the refractive index).
Here is an example:
  • Aug 20, 2025 4:51 PM UTC
Hey David,
Thanks for the tip about NPRO; this is better than NSRA with data=14 in many cases since you don’t need to know the segment number.  I learned something new today 😁!
Another approach one could take regarding calculating the EFFL is the approach that sequential mode takes:
  • Define an on-axis marginal ray from infinity in object space (the beam can be small so it’s still a “paraxial” calculation)
  • Determine the marginal ray angle in image space
  • Back propagate the image space ray to intersect with the object space parallel ray
  • The new right triangle is the EFFL
To make this work, you need to add a temporary Source Ray:
  • Make the Y Position a small but finite number (I typically use 0.01 or 0.1 so the math is easy to verifiy)
  • Make the # Analysis Rays 1
Then, the EFFL is simply:
(this is for the Double Gauss 5 degree field sample file which has an EFFL 3.99924 of  but works with any system that has a “well-behaved” optical axis...the results will start to diverge from sequential mode if you have a folded system since sequential mode ignores coordinate breaks when performing paraxial calculations but this method considers all tilts/decenters in the system)
