How to setup a 45 deg linear polarizer in the optical path
  • June 15, 2022
  • 1099 views
Ying
I have a system with a vertically polarized light as input, how to model a 45 deg linear polarizer in the optical path?
Ying
Best answer by Ethan
Hi @Ying,
Apologies on the late reply to your question. In case it is still relevant or useful to others:
One way to create a 45-degree linear polarizer is through the use of the Jones Matrix surface. By setting each real parameter of the matrix to 1 (or 0.5), you can create the intended element. I have attached a sample file to get you started.
Ethan
Ethan
  • January 3, 2023
Hi @Ying,
Ethan
Ying
  • Visible
  • January 4, 2023
Thanks, Ethan!
