How to save all tolerancing data: MonteCarlo, Sensitivity and Summary in ZOSAPI
  • May 7, 2024 2:44 AM UTC
  • 5 replies
  • 905 views
yuan.chen
The summary is in the text file. The way to save text files from the API is to use the “Output to File” entry that lives in the Classic tab of the Tolerancing tool in the OS GUI. This will save the tolerancing output by the name specified in the same folder that the system is in (be sure to include .TXT to the end). The corresponding API code for this is below:
tol.OutputFile = "OutputName.TXT"
To store the MonteCarlo and sensitivity data, we need to use the tolerance data viewer to open the saved ztd file and then store the dataset.
In order to save the .ZTD files from the ZOS-API, you will need to use the SaveTolDataFile property, and you may set the filename via TolDataFile under ZOSAPI.Tools.Tolerancing.ITolerancing Interface Reference:
tol.SaveTolDataFile = True
tol.TolDataFile = "myFile.ztd"
Then, once the tolerancing is done, from the Tolerance Data Viewer, you may read the created .ZTD files, by defining the file name and then running the tool. The corresponding python code is as follows:
TolReader=TheSystem.Tools.OpenToleranceDataViewer()
TolReader.FileName= "\Documents\Zemax\Samples\Non-sequential\Miscellaneous\Digital_projector_flys_eye_homogenizer.ZTD"
TolReader.RunAndWaitForCompletion()
To pull the Monte Carlo data for example, you may use the following lines:
mcData = TolReader.MonteCarloData()
mcDataVals = mcData.Values
mcDataTable = mcDataVals.Data
mcDataTable_reshape = reshape(mcDataTable, mcDataVals.Cols, mcDataVals.Rows)
(You can read the first row by typing: mcDataTable_reshape[0])
Be careful:
Regarding the file name definitions for the saved .TXT and .ZTD files, the files are only saved if a valid file name is provided. The filename should include the specified name together with the file extension, however, it should not include the path. The path is always the same as the current lens file. So you should only provide a file name without a path, both for the TolDataFile and for the OutputFile, such as below:
The Sensitivity Data contains different types data structures than the Monte Carlo Data.
If we take a look at the Monte Carlo data structure under the ZOSAPI.Tools.Tolerancing.IMonteCarloData Interface Reference, we can see that there is a Values property, which returns the results in a matrix format. However, for the Sensitivity Data, there is no Values property in the OSAPI.Tools.Tolerancing.ISensitivityData Interface Reference, so we cannot call it.
The sample code to read sensitivity data:
TolReader = TheSystem.Tools.OpenToleranceDataViewer()
# Choose the file we are viewing in the TDV
TolReader.FileName = 'C:\Users\...\Simple_singlet_Tol.ZTD'
# Sensitivity data
sdata = TolReader.SensitivityData
# Access criterion, compensator, operand data
criterion = sdata.GetCriterion(0)
criterionName = str(criterion.Name)
nomVal = criterion.NominalValue
# Compensator data – access the first compensator in the list
compData = sdata.GetCompensator(0)
compType = str(compData.OperandType)
compMin = compData.Minimum
compMax = compData.Maximum
compMean = compData.Mean
# Operand data – access the first operand in the list
sdOp = sdata.GetOperand(0)
sdOpType = str(sdOp.OperandType)
sdOpMin = sdOp.Minimum
sdOpMax = sdOp.Maximum
sdOpComment = str(sdOp.Comment)
sdEffect = sdOp.GetEffectOnCriterion(0)
sdEffectMax = sdEffect.EstimatedChangeMaximum
sdEffectMin = sdEffect.EstimatedChangeMinimum
# Grab some worst offender data as it applies to the first (and only) criterion
numCriteria = sdOp.NumberOfCriteria
effect = sdOp.GetEffectOnCriterion(0)
estChangeMin = effect.EstimatedChangeMinimum
estChangeMax = effect.EstimatedChangeMaximum
# Access the summary
summary = str(tdv.Summary)
Bonus:
If you want to load the tolerance script via ZOSAPI:
tool= TheSystem.Tools.OpenTolerancing
tool.CriterionScript=0
By using the GetCriterionScriptAt() member function, you may double-check the name of the file, however, it will not set the script.
tool.GetCriterionScriptAt(0)
Daniel Dominguez
Hi ​@yuan.chen! Thank you for this excellent post! Unfortunately, I’m still not seeing the desired results. Please see below. The program runs without error, but myFile.ztd and OutputName.TXT are not created. Any insight you can provide would be greatly appreciated!
from PythonStandaloneApplication import PythonStandaloneApplication
import os
if __name__ == '__main__':
zos = PythonStandaloneApplication()
# Load local variables
ZOSAPI = zos.ZOSAPI
TheApplication = zos.TheApplication
TheSystem = zos.TheSystem
# Specify location and name of Zemax File.
documents_path = os.path.join(os.path.expanduser("~"), "Documents")
if not os.path.exists(documents_path + "\\QuickTol"):
os.makedirs(documents_path + "\\QuickTol")
QT_path = documents_path + "\\QuickTol"
ZemaxFile = QT_path + "\\ZemaxOpticsDesign.ZMX"
# Set up Tolerancing Analysis
tol = TheSystem.Tools.OpenTolerancing()
tol.SetupMode = ZOSAPI.Tools.Tolerancing.SetupModes.Sensitivity
script_path = r"C:\Users\ddominguez\Documents\Zemax\Tolerance\TOLR001.TSC"
tol.UserScript = script_path
tol.Criterion = ZOSAPI.Tools.Tolerancing.Criterions.UserScript
tol.NumberOfRuns = 0 # Select number of MC runs and files to save
tol.NumberToSave = 0
tol.RunAndWaitForCompletion() # Run the Tolerancing analysis
tol.Close()
del zos
zos = None
yuan.chen
  • May 16, 2025 12:31 AM UTC
Hi ​@Daniel Dominguez, it’s sad to heear that the code does not work from your side. I am taking a new role currently and may not have time to check it quickly(I will have a look when I have time but it shall be the end of next week). If you need it urgently, please consider sending this to technical support.
  • May 18, 2025 10:35 PM UTC
Hey Daniel,
You have a few errors around setting the actual User Script.  If you look at the ZOS-API Help Syntax, there is no tol.UserScript property.  To set the User Script, you need to use the tol.CriterionScript property.  If you look at this property, it is an int and not a string, so you cannot simply pass the filename in the Zemax\Tolerance folder.  Rather, you should use the tol.GetCriterionScriptAt() method to get the index of the file (as OpticStudio sees it; mostly likely it will be in lexigraphical order but this isn’t guaranteed).
So, if you want to use a tolerance script and you don’t know what the script index is, you can use the following pseudo code:
script_path = r"C:\Users\ddominguez\Documents\Zemax\Tolerance\test.TSC"
tol_idx = None
for i in range(tol.NumberOfCriterionScripts):
if os.path.basename(script_path).lower() == tol.GetCriterionScriptAt(i).lower():
tol_idx = i
break
# ensure `tol_idx` is an actual 0-based integer
assert isinstance(tol_idx, int)
# proper way of defining the tolerance script
tol.CriterionScript = tol_idx
Daniel Dominguez
​@yuan.chen and ​@MichaelH - Thank you for your responses. As an update, I was able to integrate your suggestions in to my code. It’s been working as expected for several months. However, the latest version of Zemax (2025 R2.01) introduces several new tolerance operands (eg. ISOA, ISOB, ISOC, ISOD, and MPVT).
I updated my program to include the enum of the new operands (eg: ISOA = 57, etc.), but for some reason, they are simply skipped over. It’s as if they aren’t included in the tolerance editor.
Any suggestions on where to look? Thanks in advance!
  • Dec 8, 2025 9:52 PM UTC
Hey Daniel,
Do you have multiple versions of OpticStudio installed on your system?  If so, can you confirm that the version of OpticStudio that the ZOS-API is connecting to is actually 25R2 by using the following code:
TheSystem.TheApplication.OpticStudioVersion
This should be 250819 (or some date around this time).
Another thing to check is that the value is actually present in the enum that you are trying to get.  The following snippet will print all the names and value for the ToleranceOperandType:
for value in Enum.GetValues(zos.ZOSAPI.Editors.TDE.ToleranceOperandType):
name = Enum.GetName(zos.ZOSAPI.Editors.TDE.ToleranceOperandType, value)
ival = int(value)
print(ival, name)
If either the OpticStudioVersion is too low or the operand isn’t in the printed values, then you need to point the ZOS-API to the latest version of OpticStudio.
If this doesn’t work, please post your full code so the community can further help.
