How to model Calcium Fluoride (CaF2) accurately in Zemax
  • 18 August 2023
  • 123 views
In the UV, CaF2 begins to exhibit small amounts of intrinsic birefringence, which are non-negligible. In Code V there is a very simple way to set up a CaF2 crystal where a crystalline axis is simply established. When a retardance map is calculated for light refracted by such a CaF2 lens, birefringence shows up as “three-point” across the pupil if the light is diverging or converging through a CaF2 crystal with 111 orientation (see https://www.tf.uni-kiel.de/matwis/amat/elmat_en/kap_6/advanced/t6_6_1.html for more details). Or it can show up as a “cross” if the orientation is 001.
First of all, I’m not seeing CaF2 as a Birefringent In/Out material option. I understand I would need to define this in the Birefringent catalog. Second, I need to be able to vary the retardance magnitude and orientation depending on the crystal axis orientation and direction of propagation through the crystal. Any thoughts or suggestions?
Any thoughts on this? Is it possible to simply define a coating that imparts a spatially varying retardance signature?
