I am modeling the coupling from a laser source to a fiber. There are a collimating lens, an isolator and a focusing lens in between. If the placement tolerance between laser and fiber is +/-10um, and lenses could be actively aligned to maximize coupling, how should I set up the tolerance editor? Can I use tolerance wizard for this purpose?
How to model active alignment of multiple elements in between laser and fiber
