How to minimise distortion
Shivam
Hi everybody,
I have come across an impass in zemax. My problem statement says that I have three lenses separated by some distances. I have to move the distance between these lenses. The problem that is occurring is "distortion aberration" in the system. I've tried to  use some operand to reduce distortion by making the radius of curvature variables and now the distortion is absent in the system for a particular set of distances between the lenses. Now, when I am trying to move the lenses again, the distortion increases again.
Pictures are attached for your reference. One where distortion is zero and other when the distance between lenses have increased and the distortion increases simultaneously.
I request you to guide me so that I can move my lenses without getting distortion in the system.
Any help will be appreciated.
Thanks
Fig.1: Distortion is 0 for a particular distance (10mm distance between lens 1 and lens 2, and lens 2 and lens 3)
Fig.2: Distortion increases when the distance between Lenses increses (Distance between lens 1 and lens 2 is 20mm & lens 2 and lens 3 is 14mm)
Best answer by Michael.Young
Hi @Shivam,
I would like to follow up on your problem to see how things are going.
Originally, the question sounded like it was a homework assignment that was intended to demonstrate the methods to reduce the 3rd-order aberration of distortion (W400). However, given your comment about the image not being clear towards the edges, makes me think that may not have been the intent of the original question.
To reduce 3rd-order distortion, symmetry about the stop is the most straightforward way doing so. This means the stop should be placed near or inside of the biconvex lens. To control distortion, the DIST operand can be used.
To control for “clarity” or contrast/resolution. Use the default merit function to build the merit function and use the spot optimization at this point.
Perhaps these resources may shed some light on the design process,
https://support.zemax.com/hc/en-us/articles/1500005576302-How-to-design-a-singlet-lens-Part-1-Setup
https://support.zemax.com/hc/en-us/articles/1500005577942-How-to-design-a-singlet-lens-Part-2-Analysis
https://support.zemax.com/hc/en-us/articles/1500005577962-How-to-design-a-singlet-lens-Part-3-Optimization
Michael.Young
Hi @Shivam,
Where have you placed your stop in the example provided?
What is the purpose of the paraxial lens after L3?
What is the threshold value for too much distortion? In your second example, it is only 0.005%.
How are you supposed to vary the distances between L1, L2, and L3?
Shivam
  • August 24, 2024
Hi @Michael.Young ,
The stop is placed in the object space, before the lens 1.
The paraxial lens after L3 is representing as eye lens. We are assuming that rays coming out from the L3 lens will fall into the eye lens and converge on retina.
The distortion shown in the zemax is very less but in reality when seeing from this setup of lenses, only the center portion is clear, the edges seem to be distorted in a great amount. This is the observation from a human eye from seeing through these three lenses.
Lens 3 (which is closer to the eye or paraxial lens in this case) is fixed and distance between lense 3 & L2 is increased & then distance between L2 & L1 is changed. This is to note that L3 is closer to the eye and hence it is fixed. Lens 2 & 1 is moved.
Michael.Young
Hi @Shivam,
