How to make Reflective Slit
  • Oct 2, 2024 7:31 PM UTC
  • 164 views
whit2452
Hello there, the question is as the title states. I want to design an assembly where there is a reflective slit, how do I enable some of the rays to pass through the aperture and the other ryas to be reflected at an angle into another camera? I’ve seen resources on multi-configurations, but that is not quite what I am doing. Any resources or examples of others doing this greatly appreciated. I know it is possible, just not sure how.
@whit2452
I’m assuming you are talking about a Sequential solution since you are referring to Multi-Configuration (MC). In Sequential mode, surfaces can have apertures. To add an aperture to a surface, double-click on the surface of interest in the Lens Data Editor (LDE), or press the down arrow at the top-left of the LDE with the surface of interest selected. This opens the corresponding surface properties. Then, navigate to Aperture, and choose an Aperture Type. In the list of Aperture Types, you’ll find Rectangular Aperture/Obscuration that might be useful. There are probably many ways to achieve what you want, here’s my take:
  • Add Fold Mirror from the LDE (default shortcut Ctrl+Shft+F) to create a slanted reflective surface
  • Add a Rectangular Obscuration with the size of your slit to the reflective surface
Rays that go through the slit will be obscured and rays that fall outside the slit aperture are reflected:
You can add a configuration to show rays that are going through the aperture using the MC Editor. To do that, you’d have to do the following in a new configuration of the MC Editor:
  • Change the Aperture Type from Rectangular Obscuration to Rectangular Aperture (the size should be automatically conserved)
  • Remove the MIRROR Material of the reflective surface
  • Change the sign of the thicknesses after the aperture
  • Change the sign of the return coordinate break of the Fold Mirror
The result should look like so:
I’m attaching my example to this answer.
I hope this helps.
