It's very common to see the color tempture in the lighting industry.
Is it possible to get the color tempture for the each pixcel in the detector?
In the OpticStudio, color temperature data in the detector viewer are not provided.
However, it’s very easy to calculate color temperature from tristimulus value.
You can do the transformation by Excel, ZPL, or API.
2.
Convert X, Y, Z to CIE 1931 color space coordinate x, y by below equations.
https://en.wikipedia.org/wiki/CIE_1931_color_space
3.
If you have CIE 1931 color space coordinate x, y, the color temperature can be calculated by below formula.
https://www.waveformlighting.com/tech/calculate-color-temperature-cct-from-cie-1931-xy-coordinates
