Answer
How to generate vortex light through a phase screen by using grid sag
  • February 25, 2023
  • 667 views
pumpkin
I want to generate vortex beams by simulating a vortex phase plate in the optical path like this.
The effect I want to achieve is as shown in the first image
 Different topological loads will produce different imaging effects
by using grid sag , I wrote a dat file to create a special surface sag which is shown in the figure below. But when I looked at the simulation results using a physical propagation POP, it was very different from what I expected. I want to know how to simulate the Vortex phase plate and produce vortex beams correctly
Best answer by pumpkin
The relation between vector height, wavelength and refractive index is corrected
pumpkin
  • February 25, 2023
Hi @pumpkin!
Thank you for sharing your work. We have also published a user defined dll if it helps:
