How to extract MTF data from multiple lens configurations?
  • Mar 11, 2025 12:25 AM UTC
  • 197 views
Dear Optical Design Fellows,
I used Tol Script to tolerance the lens. The lens tolerance is completed at nominal object distance and I need to pull out lens MTF data at other object distances/configurations with Tol Script. Is there an way/ a command in tol Script to extract lens MTF data at other object distances/configurations after tolerancing at nominal distance? Specifically, the lens is completed tolerance analysis at object distance 1000mm, and I want to pull out MTF data at object distance at 500mm and Infinity using tol script. Is there a way to pull out the lens MTF data with Tolscript command?
Zhisheng Yun
  • Mar 11, 2025 12:33 AM UTC
Continue to the lens MTF data pull out from multiple configurations… I run Monte-Carlo analysis with 500runs… Would like to pull out lens MTF data at multiple object distances with each set of tol setups for the lens stack...
Yang.Yongtao
  • Apr 24, 2025 6:01 AM UTC
Hi ZY
I guess in Zemax Help manual
10.2.14.48. GETMTFUSER1D  or 10.2.14.49. GETNSCMTF may solve your issue
