How to define distance between lenses in paraxial optics
  • Feb 14, 2021 12:19 PM UTC
  • 263 views
I have a system of two lenses with f1=10cm and f2=20cm. Magnification is M=-1.1x.
We take two lenses be following links: https://www.newport.com/p/KBX166 and https://www.newport.com/p/KBX154 .
And need to define a distance between these two lenses if we place an object in 2cm from the front focal point.
So in terms of this task, I have two questions:
1. How can I define in Zemax distance between the first lens and the object if I know that between the object and the FFL it is 2cm.
2. How can I measure the distance between two lenses and the total throw?
Thank you in advance!
