How to confirm the focuses resulted by birefringent material at the same time?
  • November 12, 2025
  • 29 views
Yang.Yongtao
Hi zemaxers
 I am learning about birefringent materials, and my question is
the image expected is below
Best regards
Yang
Yang.Yongtao
  • 76 replies
  • November 13, 2025
Sorry for bothering
 Huygens PSF can deal with this issue
Ansys Staff
  • Ansys Staff
  • 411 replies
  • November 14, 2025
Hi Yang,
Yes, you found the solution I was going to recommend.  Basically, using a Birefringent Surface is the same as using a multi-Config system and there are only a handful of analysis that support multi-config systems.  Any ray based analysis can simply be superimposed in a multi-config system to provide the output, but if you need a diffraction based multi-config analysis, the Huygens PSF with Config=All is one of the most powerful tools that OpticStudio has.  I would avoid any pupil-based calculations including FFT analysis because there is no “common” image-space reference point to superimpose the results onto a common plane.
